Tire Size comparo?
Old Mar 9, 2004 | 09:51 PM
vodoo-chile's Avatar
Tire Size comparo?
I currently have 17x9 SS wheels and 275/40/17's at all 4 corners. My car has been "tracking" pretty badly and everyone tells me it is normal for 275's. When I had my 245/50/16's, it never did this so I want to go back to 245's, but with the 17x9 rims. I assume it is possible and would not look "too funny", as I have seen other people with 245's on 17's, but what size tire should I get for the fronts and keep the same diameter if I plan to leave the backs at 275/40/17? Thanks,
Kyle
Old Mar 9, 2004 | 11:55 PM
CODY BEHNKE's Avatar
If you run a 245/45R17 they will be only a 10th of an inch shorter.
Old Mar 10, 2004 | 01:39 PM
Thanks, Cody. I am assumming that with the 17x9's, the tire won't look to small width wise.
Kyle
Old Mar 10, 2004 | 05:22 PM
What brand are you going to run? Even though a tire might be the same size some manufactures are wider than others.
Old Mar 10, 2004 | 06:05 PM
I'm not sure. I haven't even thought about tire brand. Any suggestions?
Kyle
Old Mar 10, 2004 | 10:10 PM
BFGoodrich tires are usually wider per size.
Old Mar 11, 2004 | 12:10 AM
Gold Z's Avatar
Don't be surprised if you change tires and find you have the same problem. I suspect your front wheel alignment is slightly off. Take your car to an alignment center and have it checked.
Old Mar 11, 2004 | 09:39 AM
I did get an alignment originally. Didn't help much. I also have a hard time believing that it is a couple of exrtra inches in tire width making that much of a dramatic change but everyone I have talked to said that the 275's will do this.
Kyle
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
LD Kirk
Apr 30, 2015 08:54 AM
blac94Z
Mar 6, 2015 07:55 AM
cristian1311
Mar 4, 2015 04:45 PM
