Throwout Bearing adjustment?
Old Nov 28, 2007 | 01:13 PM
Wild1's Avatar
I have a 95 Z28 with a T56. I just replaced the throwout bearing and it is making a rattling sound at idle. When I press in the clutch the sound goes away. Since the sound goes away it isn't the pilot bearing or the input shaft. The clutch grips fine and doesn't chatter.
Anyways, if I push slightly on the clutch release lever the sound will go away. Is there any adjustment I can make on the hydraulic clutch assembly or near the lever to shim it so the sound goes away?
Thanks.
Old Nov 29, 2007 | 12:31 AM
95LT1conv's Avatar
Nope, just something you have to deal with. Mine has done it with 3 different clutch sets.
Old Nov 30, 2007 | 11:23 AM
Wild1's Avatar
That is annoying! Is it too much space between the bearing and the shaft? Is it a poor design? I wonder why it has to rattle like that.
Old Nov 30, 2007 | 12:25 PM
Green96Z's Avatar
After my swap I don't have any rattle/clutch chatter. None I can hear anyway. I installed a Ram HDX clutch. One thing I did was lube the T/O bearing and input shaft with high temp. grease, as the T56 manual says.
Old Nov 30, 2007 | 01:46 PM
wrd1972's Avatar
No adjustment to the TOB in your application. The sound may go away and if it does not it should be totally harmless. I have had brand new ones do it which really sucked.
Old Nov 30, 2007 | 07:48 PM
Wild1's Avatar
Yes, we did lube the inside of the bearing and the fork (lightly). I suppose there isn't much I can do about it unless I pull it apart again and try a different bearing. I was hoping I could put a little tension on the bearing to stop the noise but that would just ride the clutch.
RUENUF
Mar 13, 2016 03:37 PM
93 RedBird
Nov 15, 2015 08:24 AM
HibachiZ28
Nov 6, 2015 12:53 AM
Bxlt1
Sep 17, 2015 08:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
