Those w/ Mcleod Street twin inside
Old Aug 23, 2003 | 08:06 PM
Mizz96Z28's Avatar
Who here has a street twin installed on their car and just bolted it right in without balancing the flywheel/PP? I want to install mine but I've been told to balance the new flywheel to the old then the new PP to the new rebalanced flywheel but I also get people telling me to just throw it in and it should be fine. So whats the way to do it? Has anyone just put it in their car right out of the box without any problems? Has anyone put it directly in and ended up having problems? Any help or experiences you've had with this would be much appreciated.
Myles
Old Aug 23, 2003 | 08:18 PM
iniviate's Avatar
Re: Those w/ Mcleod Street twin inside
Myles
i had to have mine balanced. i put it in and had a very bad vibration. turns out the pressure plate was WAY off.
then .... a friend used his right out of the box with no problems.
Old Aug 23, 2003 | 08:41 PM
Mizz96Z28's Avatar
I suppose I'll just go get it balanced then to make sure. Better safe than sorry and I don't want to do this job twice if I can help it.
Myles
Old Aug 23, 2003 | 11:11 PM
Brent94Z's Avatar
Super Moderator
I'll move this over to the new Drivetrain forum...
Old Aug 23, 2003 | 11:38 PM
RCF925's Avatar
You have to balance the Mcleod S/T to your crankshaft just like you should do with any other aftermarket clutch set-up. LT1 are neutral balanced on the front but must be balanced at the rear.
Old Aug 30, 2003 | 02:46 AM
m0nk's Avatar
Anyone here install the street twin themselves? I think I either lost the instructions for the master cyl install, or they dont give them out... Either way, in the bag of 2 screws that came with it there is a metal plate with a clover stamped on it, and a slot cut out of it, what is it for?
Old Apr 26, 2004 | 02:23 AM
Dave88LX's Avatar
How do you balance the whole clutch assembly?
Old Apr 26, 2004 | 02:51 AM
IllusionalTA's Avatar
mcleod balance's the entire assy.. They then mark it w/ a blue/black marker as to how it's to be installed.. It comes the way it needs to be installed.. IF you put it together "EXACTLY" how you take it apart you'll have no problems.. Trust me...
Old Apr 26, 2004 | 11:58 AM
crzhrs's Avatar
Wow, ya'll drug this post out of the past! But, since you did... like monk I am curious what that plate with the clover is for. Anyone know?
Old Apr 26, 2004 | 04:03 PM
It come's w/ the Master cylinder.. W/ LS1's its used to take the line out of the slave cyl. on lt1's its useless...
Old Apr 26, 2004 | 05:48 PM
crzhrs's Avatar
Ahh, Now I can sleep at night.
Old Apr 27, 2004 | 12:09 AM
Dave88LX's Avatar
<-----------Guilty of using the search button.
Does the McLeod flywheel have the EXACT same balance as a stocker? I'm building a 383 right now, and have already had my rotating assembly balanced with my stock flywheel, I'd hate to get this clutch and have it screw up my balance?
dolfan324
Jul 17, 2015 10:34 PM
Latronaxe
Jul 17, 2015 11:55 AM
RUNMYTA
Jul 15, 2015 07:50 PM
