Those with built trans or trans builders (A4s)
Old Jul 16, 2004 | 09:13 AM
Shon Herron's Avatar
I see alot of people getting built transmissions and then they fail and I have often wondered if any one discussed the trans table setting in the PCM once the new trans was installed.
I know from when I had an A4 I spent more time on those tables than the spark and fuel to get it to shift the way I wanted it to and when I wanted it to. With that came alot of changes in the tables and if those tables are never discussed with the builder how is the trans supposed to live? B/c my thoughts are that I probably was tuning a worn out trans and therefore those same settings should not be used on even a stock rebuild.
What are others thoughts on this? Does this conversation happen at the consumer/builder level?
What are the recommendations? B/c line pressure is critical and that is one of the major things that the PCM tries to control. I figure shift points are left up to the combo but what about other aspects?
Fastbird93
Apr 9, 2016 07:01 PM
james007moore
Jan 1, 2016 01:14 PM
ChrisFrez
Mar 1, 2015 01:33 PM
Bearmans
Dec 3, 2014 05:28 AM
