Th 400?
Old Oct 3, 2003 | 11:57 AM
POSSESSEDZ's Avatar
Th 400?
Need suggestions for Rebulid Kit etc.... for a TH 400 ,Iam building a 383 moter w/ gm 847 cam, stock heads ported (maybe AFR heads if i have the $), 100 shot of nos with 12 bolt rearend.
Should i get the B&M , TCI or HUGHES kit which is the better of the 3
Old Oct 3, 2003 | 12:26 PM
JPSartre12's Avatar
Re: Th 400?
My car has an ATI TH400 w/tb and Turbo Action's Cheetah reverse pattern shifter working a manual valve body.
While I'd admit that it's "different", it isn't hard to get used to.
I still have to decide how I'm going to mate a speedometer/odometer to the tranny, but that's minor.
The choice of a 4.10 rear by the previous owner is more of a concern to me. With a TH400 that has a 1:1 third gear, highway driving is a real chore. I'm contemplating swapping it out for a 3.42 rear so that I can drive on highways for more than a few miles at a time. I'm hoping that gas mileage will also improve with the change. I think that the car has enough HP (especially once I use the 200HP NOx shot) to handle the rear change and it'll improve the car's topend.
Good luck with your project. I love the torque that strokers provide. Yesterday, I had to pull out from a side street quickly in order to take advantage of a rare gap on a busy road and wound up smoking the tires through 1st and 2nd gear under moderate throttle. I may be 47, but there's nothing better than seeing smoke coming off of my tires.
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
Kawi
Sep 28, 2015 09:01 AM
Z Power
Sep 19, 2015 11:19 PM
