TH 350 swap-94Z28 questions.
Old Sep 22, 2003 | 06:05 PM
LALT1's Avatar
Question TH 350 swap-94Z28 questions.
Ok I am really over changing the 4L60E's out and want to go with the TH350 for price and reliability reasons. The OD doesn't mean that much to me. What all is need to do the swap? And has anyone come up with a adapter yet to run the speedo?
Old Sep 23, 2003 | 08:25 AM
Shon Herron's Avatar
You will need a TH350 and a TC.
Stock TA or stock style TA you will use the B&M kit for the swap, it has all that you need.
Non Stock TA style you can get your stock trans crossmember modified to work.
I am using the Dakota Digital SGI 5A and the SEN 01 to run the speedo.
You will also need/want a shifter.
Not that bad of a swap...oh and a dip stick tube from MadMan.
Old Sep 23, 2003 | 09:53 AM
rskrause's Avatar
Moderator
Why not go for a TH400 if you don't care about OD?
Rich Krause
Old Sep 23, 2003 | 10:00 AM
Rich Krause
Either one is fine for this application. and if the 2 are built right i can not see the difference. other than the TH350 being lighter, from what i have been told. but this debate rages on for ever.
Plenty of fast cars with both set ups...
Old Sep 23, 2003 | 05:15 PM
LALT1's Avatar
Thanks alot for the info, was wondering about the B&m kit since they actually list it for a 3rd gen, and hadn't been able to get anyone to help me with the speedo. thanks again.
Old Sep 23, 2003 | 11:58 PM
D James's Avatar
From what I remember, the th400 is more close in length to the auto trans you have now, might even fit without having to cut up the driveshaft, plus that trans is stronger
Old Sep 24, 2003 | 02:50 PM
LALT1's Avatar
one more question? Driveshaft and did you use the 6" tail shaft 350th? which is the short one.
Old Sep 25, 2003 | 07:04 AM
I used the 9" tail shaft for the TH350, stock DS is used in my car.
Old Sep 25, 2003 | 07:28 AM
JPSartre12's Avatar
I just picked up a 94Z w/396 stroker with a worked TH400 and want to hook up a speedometer and odometer. What parts are needed for the project? How difficult is it to do?
Old Sep 25, 2003 | 07:34 AM
Go to LJ's site and you will find the GM part numbers for the TH400 set up.
HAWG
Sep 25, 2015 11:41 AM
MDZ28
Sep 7, 2015 09:16 PM
Rittmeister
Aug 7, 2015 01:13 AM
Henson071
Aug 4, 2015 09:32 AM
