CamaroZ28.Com Message Board
-   Drivetrain (https://www.camaroz28.com/forums/drivetrain-44/)
-   -   Technical Question??? (https://www.camaroz28.com/forums/drivetrain-44/technical-question-884277/)
Stephen68 May 1, 2016 07:25 PM
I have looked all over but cant find the answer...On my 95 TA with factory 4L60E, i just replaced the rear universal joint....Do i need to use all 4 circlips or just 2? If i am supposed to use all 4, does anyone have a pic of where the 2 with the saddle straps goes at? Thanks!
shoebox May 2, 2016 07:44 AM
Re: Technical Question???
The pinion yoke does not require clips because it has little tabs to keep the bearing caps from going anywhere.
Stephen68 May 2, 2016 12:48 PM
Thank you Fred, would you have or know of a pic showing the tabs...I cant see anything on my pinion yoke....
shoebox May 2, 2016 09:52 PM
I'm not Fred, but I just looked at a pic I have of an LS rear yoke and there are no tabs. I know there are on older rears. Anyway, the cups wont go anywhere after you install the driveshaft and put the straps on.
