TCC lock-up Issue solved?
Old Jun 7, 2004 | 09:39 PM
97pontta's Avatar
Sorry a little long but....
A few months back I installed an EDGE 3400 lock-up converter. The thing performs great, I actually picked up about 1.5 MPH in the 1/4, and knocked off about .7 with traction. But that’s all great.
From day 1 I had a problem with the converter unlocking going down the road at 50+ MPH. Some times it would lock up and go 2 miles and then it would go 20 with out doing it. I've been frustrated and tried a number of things including replacing the TCC solenoid, wire harness, other solenoids and tranny temp sensor. None of this fixed it.
I had done some searching on this board and other and found nothing like the problem I had. I was looking on an LS1 board and found a sticky about random TCC unlock on the freeway. They said the problem was with the smaller diameter TC and less rotating mass, thus causing a false misfire, then unlocking the TCC. Has anyone else had these kind of problem with an LT1 and 4L60E?
Anyway I talked to Bryan Herter and he said he has only seen 1 or 2 LT1s with this problem and that the LS1 misfire diagnosis is more sophisticated than the LT1's. Anyone else out there with this problem or had this problem?
MyfateZ28
Oct 5, 2015 12:36 PM
lildemars09
May 28, 2015 07:54 PM
Gio93z
May 21, 2015 02:56 PM
David Dorris
Jan 17, 2015 08:10 PM
SAR2K
Sep 1, 2002 10:49 AM
