TB effect tranny shiftpoints?
Old Sep 8, 2006 | 11:10 AM
ajlew9428's Avatar
I have a 94z with 115,000 miles. I have the basic bolt ons(kn intake, headers, etc) but not long ago, I installed a 52 mm TB, reusing gaskets. After I did this, my tranny was shifting soft, and early(also lagged a little). I thought the computer might adjust after 100 miles or so, but after about a month, I couldnt stand it any more, and took it off. I replaced my stock 48mm, reusing gaskets, and everything went back to normal, which I like.I searched for information regarding this subjust, and have found very little information on it. Ive read up on a couple of possible answers,(Tps, vacuum leak, tranny line pressure) but im not sure what the problem actully is. I dont know all of the factors on a throttle body that could effect the transmission shiftpoints. I bought the throttle body from a guy on ebay, rebuilt and ported. The throttle body looks good. Someone please help
Old Sep 8, 2006 | 11:29 AM
anaik's Avatar
Re: TB effect tranny shiftpoints?
The line pressure needs to be raised when using a 52mm or 58mm TB with an A4. The TPS is instrumental in determining shift firmness. For instance with the 52 the PCM is seeing less throttle opening than a 48 for the same amount of air that is being used, therefore it will shift softer. This can be corrected by one of our resident tuners.
Old Sep 8, 2006 | 05:03 PM
ajlew9428's Avatar
Thanks for the info anaik. I have been wanting to get my car dyno tuned. would I be able to correct this problem with a dynotune, or would you recommend something else?
Old Sep 8, 2006 | 05:28 PM
anaik's Avatar
The tuner should be able to bump the pressure up. If he can't get another tuner.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
92_RS_305
Sep 8, 2015 07:47 PM
