and....the TA breaks down.
Old Jan 3, 2007 | 03:33 PM
dre2013's Avatar
so the past few days my clutch has been squeaking sometimes when it is depressed...then the last time i drove it (4 days ago) i could feel alot of vibration through the clutch pedal. Well yesterday the weather was nice so i decided to take it out for a lil bit.. i washed it, put gas in it, and drove about 5 miles, and i was in 4th gear, pulled it out to put it in neutral and it came out really harshly as if i wasnt even using the clutch...i released the pedal and it barely came up at all. i pressed it down again and it was really stiff, squeaked, and i tried to press it down more and i heard a grinding noise so i didnt bother with it any more, and just coasted into a parking lot. I tried to start it about 30min later and it wouldnt even turn over. I also noticed right before it happend i was idling in a friends driveway and with it in neutral without pressing the clutch i could hear a rattling noise that wasnt too loud, but i could hear it over my car with open exhaust cutout. Any ideas on what this could be? I was thinking possible slave cyl, or throwout bearing. Someone else also suggested a bad flywheel. Clutch/trans/motor all have 6k miles on them. and clutch is a spec stage 2. Thanks,
James
Old Jan 3, 2007 | 04:19 PM
davidarel's Avatar
slave cylinder sounds like a good culprit. It very well might be the master cylinder too though. How new is the clutch in the car? The rattling sounds like a bad throwout bearing but with a bad slave and no pressure on the fork, it could make some strange noises.
Old Jan 4, 2007 | 10:16 AM
dre2013's Avatar
my mechanic jsut called me, he said my engine might be seized. I know it isnt though b/c it was idling right before i shut it off and the oil level and everything is good. Any ideas before the tranny gets dropped?
Old Jan 4, 2007 | 11:32 AM
davidarel's Avatar
Either way, I think you are going to have to drop the trans. It is something with the clutch assembly.
Old Jan 4, 2007 | 11:53 AM
dre2013's Avatar
just got back...he said slave cylinder, but now the problem is seeing what caused it to fail...he thinks i could have broke afew teeth on the clutch? this is going to cost me around 1200bux damnit..good thing i paid attention to everyone else and kept a daily driver lol
Old Jan 4, 2007 | 12:58 PM
87lt1rx7's Avatar
this happened to me and i essentially blew up the clutch. clutch had material left but just broke apart. this was on a stock clutch however, but same symptoms.
Old Jan 4, 2007 | 11:03 PM
byrons1502's Avatar
pull the trans yourself and see. its not that hard by yourself. sound like the clutch went bye bye
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
