Stud kit for Rear end covers
Old Jun 8, 2005 | 10:44 PM
Bow94z's Avatar
When you buy just the TA cover, you get all the bolts you need including the center bolts...but what exactly is the stud kit that you can buy optional??? what is so different about the optional stud kit than the regular bolts it comes with
Old Jun 9, 2005 | 03:30 AM
GreenDemon's Avatar
Re: Stud kit for Rear end covers
Well, I won't get into the strenght of studs vs. bolts conversation, but I do know that it would certainly be nice to just slide the cover onto all the studs and turn the nuts on, instead of trying to hold the cover up while you're thread the bolt through over half an inch of aluminum to a hole that isn't very happy. For what it's worth, my car currently has a 9 bolt since I can't seem to get one of the bolts to catch.
Old Jun 18, 2005 | 01:36 AM
Bud M's Avatar
The studs are not for holding the cover on. They are for the bearing caps inside the rear end.
Old Jun 18, 2005 | 04:54 AM
Projectz28's Avatar
Moderator
exactly
The "stud kit" is not for the cover. the cover is always held on by bolts. The studs take the place of the bearing cap bolts that hold the carrier in place. If you just hold a stud and nut against a a stock bolt its not hard to see why the studs are so much stronger. The dont flex or strech like a stock bolt under heavy loads. This in tern hold the carrier in place better and results in less carnage on a hard launch.
Old Jun 18, 2005 | 03:48 PM
GreenDemon's Avatar
Oh ok I thought it was for the actual cover. I didn't know the studs for the caps were an optional item, figured they all came like that, or at least the ones I've seen for the 10 bolt.
Old Mar 3, 2006 | 08:39 PM
nfa's Avatar
nfa
Does anyone know the specs for the stud kit (i.e. thread pitch and dimensions) I just want to know if I can pick up the studs and bolts locally in the appropriate grade instead of shelling having them shipped.
oldschool
Feb 9, 2016 09:21 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
