For strength which gear ratio is best 373 or 410
Old 01-27-2007, 07:48 PM
remaxracer45's Avatar
I have a 96 WS6 about 400 to the rear with a 6 speed , i'm changing gears til I can upgrade to a better rear end. I have a girdle, welded tubes and upgraded axles, I want to put in the stronger of the two ratios. I have hear varied opinions on this what is yours?
remaxracer45 is offline
Old 01-27-2007, 10:51 PM
nodnarb481's Avatar
I believe the higher the ratio the weaker they become.. I could be wrong. BUt i would assume then that the 3.73 would be stronger the then 4.10. Im sure someone more certain will chime in tho
nodnarb481 is offline
Old 01-28-2007, 12:03 AM
StephenDeli22's Avatar
3.73 will have more meat on the gear teeth
StephenDeli22 is offline
Old 01-28-2007, 01:17 AM
seawolf06's Avatar
4.11
seawolf06 is offline
Old 01-28-2007, 01:30 AM
Daniel6718's Avatar
ive been 1.50 60' on 3.73 before
Daniel6718 is offline
Old 01-28-2007, 01:45 AM
seawolf06's Avatar
A4 doesn't put as much stress on the rear as the M6 does.
Old 01-28-2007, 07:39 PM
Capn Pete's Avatar
Originally Posted by seawolf06
4.11
Subject to contradicting evidence/experience, I'd have to agree . They use a 37/9 tooth count vs. the 41/11 or 41/10 that 3.73's/4.10's/ use. Less teeth on the ring should mean thicker teeth.
Depends what you're doing with the car though, and also what tranny you've got. As mentioned, an A4 will be A LOT easier on the diff than an M6 (but then it's almost pointless swapping from the factory 3.42's to 3.73's if that's what you're planning on doing? )
Capn Pete is offline
Old 01-28-2007, 07:42 PM
seawolf06's Avatar
Yeah, going just to 3.73 is almost worthless. The 4.11 has even less teeth than the stock gear ratios.
Old 01-28-2007, 10:04 PM
who makes a good 411 gear?
Old 01-28-2007, 10:05 PM
seawolf06's Avatar
GM does
Old 01-29-2007, 12:28 AM
Capn Pete's Avatar
GM makes true 4.11's for the 7.5" / 7.625" 10-bolt?? Are you sure????
Old 02-04-2007, 03:10 PM
cwalsh
Guest
Posts: n/a
3.73 would be stronger> I have broke 2 sets of 4.1x's
Old 02-04-2007, 03:39 PM
seawolf06's Avatar
You broke some 4.11's but not the 3.73s? Is it because you drive safer on the new gears?
Yes, my gears are stamped with GM.
10 teeth on the pinion and 41 teeth on the ring gear (41/10= 4.10)
9 teeth on the pinion and 37 teeth on the ring gear (37/9 = 4.11)
Old 02-04-2007, 04:01 PM
cwalsh
Guest
Posts: n/a
1st time was at the track launching, 2nd time was on the street. I pretty much drive it like I stole it!! after 500 mile break in on the gears. I now have a 9"
Old 02-04-2007, 07:30 PM
seawolf06's Avatar
http://mikronite.com/dyno.asp
http://cranecams.com/index.php?show=mikroniteProcessVid
anmar A
05-02-2015 06:59 PM
04-16-2015 09:57 AM
thenewkid
04-12-2015 07:42 PM
07-04-2005 05:00 PM
Quick Reply: For strength which gear ratio is best 373 or 410
