For strength which gear ratio is best 373 or 410
Old Jan 27, 2007 | 07:48 PM
remaxracer45's Avatar
I have a 96 WS6 about 400 to the rear with a 6 speed , i'm changing gears til I can upgrade to a better rear end. I have a girdle, welded tubes and upgraded axles, I want to put in the stronger of the two ratios. I have hear varied opinions on this what is yours?
Old Jan 27, 2007 | 10:51 PM
nodnarb481's Avatar
I believe the higher the ratio the weaker they become.. I could be wrong. BUt i would assume then that the 3.73 would be stronger the then 4.10. Im sure someone more certain will chime in tho
Old Jan 28, 2007 | 12:03 AM
StephenDeli22's Avatar
3.73 will have more meat on the gear teeth
Old Jan 28, 2007 | 01:17 AM
seawolf06's Avatar
4.11
Old Jan 28, 2007 | 01:30 AM
Daniel6718's Avatar
ive been 1.50 60' on 3.73 before
Old Jan 28, 2007 | 01:45 AM
seawolf06's Avatar
A4 doesn't put as much stress on the rear as the M6 does.
Old Jan 28, 2007 | 07:39 PM
Capn Pete's Avatar
Originally Posted by seawolf06
4.11
Subject to contradicting evidence/experience, I'd have to agree . They use a 37/9 tooth count vs. the 41/11 or 41/10 that 3.73's/4.10's/ use. Less teeth on the ring should mean thicker teeth.
Depends what you're doing with the car though, and also what tranny you've got. As mentioned, an A4 will be A LOT easier on the diff than an M6 (but then it's almost pointless swapping from the factory 3.42's to 3.73's if that's what you're planning on doing? )
Old Jan 28, 2007 | 07:42 PM
seawolf06's Avatar
Yeah, going just to 3.73 is almost worthless. The 4.11 has even less teeth than the stock gear ratios.
Old Jan 28, 2007 | 10:04 PM
who makes a good 411 gear?
Old Jan 28, 2007 | 10:05 PM
seawolf06's Avatar
GM does
Old Jan 29, 2007 | 12:28 AM
Capn Pete's Avatar
GM makes true 4.11's for the 7.5" / 7.625" 10-bolt?? Are you sure????
Old Feb 4, 2007 | 03:10 PM
cwalsh
Guest
Posts: n/a
3.73 would be stronger> I have broke 2 sets of 4.1x's
Old Feb 4, 2007 | 03:39 PM
seawolf06's Avatar
You broke some 4.11's but not the 3.73s? Is it because you drive safer on the new gears?
Yes, my gears are stamped with GM.
10 teeth on the pinion and 41 teeth on the ring gear (41/10= 4.10)
9 teeth on the pinion and 37 teeth on the ring gear (37/9 = 4.11)
Old Feb 4, 2007 | 04:01 PM
cwalsh
Guest
Posts: n/a
1st time was at the track launching, 2nd time was on the street. I pretty much drive it like I stole it!! after 500 mile break in on the gears. I now have a 9"
Old Feb 4, 2007 | 07:30 PM
seawolf06's Avatar
http://mikronite.com/dyno.asp
http://cranecams.com/index.php?show=mikroniteProcessVid
anmar A
May 2, 2015 06:59 PM
Apr 16, 2015 09:57 AM
thenewkid
Apr 12, 2015 07:42 PM
Jul 4, 2005 05:00 PM
