Street-Twin without the Adjustable MAster Cylinder..
Old Sep 18, 2003 | 10:41 PM
xxsaint69x's Avatar
I am fixing to get a Street Twin, the only problem is it does not come with a adjustable master cylinder. I was wondering if i will be ok with the stocker.
Marcin
Old Sep 18, 2003 | 11:53 PM
AL SS590 M6's Avatar
Moderator
Re: Street-Twin without the Adjustable MAster Cylinder..
Marcin
Most are ok with the stock master. Some aren't and there's no way to tell ahead of time.
Old Sep 19, 2003 | 06:19 AM
xxsaint69x's Avatar
what kinda problem i might run into if i dont use one?
Old Sep 19, 2003 | 07:00 AM
PatriotTA's Avatar
Don't do it!! You won't be able to disengage the clutch without it. Trust me, I've talked to McLeod tech myself, and they said its highly recommended for their single disc setup and a must for the street twin. I'm even having problems with my single disc setup and stock hydraulics. What will happen is your clutch will disengage a little, but not fully, causing it to be slipping instead of disengaging. I just pulled my single disc setup out of the car after about 800 miles and it looks like it has thousands of miles of wear from the slipping.
Old Sep 19, 2003 | 08:05 AM
xxsaint69x's Avatar
ok....is there any difference between the old street twin (the one that didnt come with a master cylinder and between the new ones?) Also who has the best deal on the whole package? I think racenet has the whole thing for 890.
thanks
Marcij
Old Sep 19, 2003 | 08:56 AM
PatriotTA's Avatar
thanks
Marcij
Not sure about the "old" ones and "new" ones, but you can get McLeod's phone # on their website. I think its http://www.mcleodind.com. If you call them, they are really helpful. When I talked to tech, they said the best prices are usually from Thunder Racing, since they order a lot of parts. I've dealt with Thunder many times, and they are awesome. I've heard quite a few negative things about RaceNet before, so I would stay away from them, even if they have a little cheaper price.
Old Sep 19, 2003 | 11:50 AM
jgeorger's Avatar
Thunder Racing is great and I would pay a little more to get it from them over a bad vendor. However, I got my ST thru a GP from Combination Motorsports in June at a great price. The only problem - not their fault - is that the flywheel got backordered.
Old Sep 21, 2003 | 11:51 PM
trax's Avatar
At least with my installation the clutch pedal has an awful lot of pushback to it... I've only driven one stick LT1 (my own) for more than a couple minutes, but the Street Twin does have a good deal more pedal tension than, say, a SPEC Stage III. I would guess that means it's harder on the hydraulics.
Old Sep 22, 2003 | 12:25 PM
missetti's Avatar
I just bought one from ACA Performance, $875, real nice peopleto work with. Showed up a week later to the day, Kevin
Old Sep 24, 2003 | 09:09 AM
xxsaint69x's Avatar
well its been ordered
now, where can i buy just the slave cylinder?
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
Daluchman1974
Sep 11, 2015 06:12 AM
