Stock gear ration questions
Old Jul 8, 2005 | 06:21 PM
JadedZ28's Avatar
i have an m6 '02 z28, i kno i have 3.42's out back, but was that the only gear ration you could get, or was there an option for 3.73's?
The reason i ask is because my rear end is still howling under load on the highway, and im wondering if the gears are the problem. If so, id rather them replace the gears with a higher OEM raito if that was an option... thanks guys =)
Old Jul 8, 2005 | 07:38 PM
SFB767's Avatar
Re: Stock gear ration questions
All M6s had 3.42s (RPO code GU7), there was no 3.73 option.
A4s either had 2.73s (RPO code GU2) w/a steel driveshaft or 3.23s (RPO code GU5) w/an aluminum (silver) driveshaft.
Old Jul 8, 2005 | 08:15 PM
Greed4Speed's Avatar
I'd rather not ration my gears.
If you're asking if you can put in a higher ratio, then the answer is yes. 3.73:1, 4.11:1, etc.
If your rear is howling then you have problems.
Old Jul 10, 2005 | 12:17 AM
BirchMan98z's Avatar
Howling rear= cracked differential pinion seal (DPS). Cheap fix, I'd look at that first. Rear ends in general are not expensive to repair.
Old Jul 11, 2005 | 07:35 PM
mrr23's Avatar
it's GU6 for 3.42 GU7 is 2.77
Old Jul 11, 2005 | 08:57 PM
mudpuppy's Avatar
GU2 = 2.73
GU4 = 3.08
GU5 = 3.23
GU6 = 3.42
GU80 = Axle, Positraction
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
ChrisFrez
Jan 11, 2015 03:47 PM
cmdeshon
Dec 27, 2014 10:06 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
