Stall questions??? 2800 guys!!!
Old Jan 11, 2006 | 12:39 AM
scottslt1z28's Avatar
Ok, so my next step in modding is either a cam or a stall
i am leaing towards a stall because i am leaving going into the motor until last.
I am looking at a Vigilante 2800
what would i expect to see??? where would i be able to launch?? (2800 or lower???)
where would it just Roll-out at when i am moving from a stop through stoplights??? does it affect cruising?? RPM's........where would the car shift at now when i am launching at the strip?? (1st is 40 now, 2nd is 80.....and so on) would it change
i am a stall newbie so please guys help me out. (i am searching for info too, but these are just some direct questions i had)
thanks a lot guys.....Scott
P.s.-- i would have my computer retuned for the stall and throw a shift kit with a tranny cooler in there..........What are some things i would see?? How would it affect my tranny and so forth??? (mods are in sig)
Old Jan 11, 2006 | 11:22 AM
MyShibbyZ28's Avatar
Re: Stall questions??? 2800 guys!!!
Tranny cooler is a must. I plan on doing some of the same things you are, leave the engine till last. The tranny cooler isn't hard to install, just time consuming.
Also, I don't know if it's because you have 3.23 gears, but I shift at 55-60mph in first, and almost around 90+ in second to third.
Some people say the stall takes off .2 or something from their times.
Old Jan 11, 2006 | 02:25 PM
think u have a 2.73 car. if you cant put it in first on the center console then u do
and i have heard as much as a .6 off of ET, but it just depends on how well you could hook b4. Im guessin 60fts with a 2800 would be 1.6.....1.5 is kinda pushin it but i dunno (and usually for ever .1 down with 60 ft time is about .2 tenths reduction in ET. Of course depending on what speed you are traveling..........12's-14's)
Old Jan 11, 2006 | 09:25 PM
I already know I do. Just wondering if that MPH difference is from the gears. Can't be anything else so...
Old Jan 11, 2006 | 09:42 PM
nope........cruising MPH is strickly dependent upon gears.
Old Jan 12, 2006 | 08:04 AM
Capn Pete's Avatar
Yes, it's the different gear ratios affecting the speed at the shift points. ~55 mph 1->2 and ~95 mph 2->3 is right for 2.73's .
As long as you can hook, you can expect to take upwards of ~.5 seconds off your 1/4 mile time, but not off your 60' time . At least I don't think a stock-"ish" LT1 would cut 1.5's - 1.6's with just a 2800 stall? I'm sure you could easily expect 1.8's, and possibly 1.7's though (that's a couple tenths quicker than normal 60' times, and should translate to ~.4 - .5 off the 1/4 mile time).
As far as shift points go, AFAIK there shouldn't be much difference in your speed at the shift points due to the stall. And cruising RPM's should stay the same as long as you run a lock-up converter, same as stock.
Old Jan 12, 2006 | 09:09 AM
So when u are getting on it from a dig and ur RPM's are starting at lets say 3000 with the stall. Will the shift points be the same??? or will the converter just not let the motor climb anymore in the RPM range until it has matched the same speed as 3000 then it will start to climb???? is that the way it works?
Old Jan 12, 2006 | 10:09 AM
Capn Pete's Avatar
The shift points at WOT (wide open throttle) will stay the same, and at that point, the engine is turning well beyond stall speed, so the tranny won't know the difference.
The stall doesn't mean the car won't start to move until the motor is turning at stall speed, it will drive just like normal under "normal" driving (light - moderate acceleration). It's only when you step right into it that you'll really notice the motor rev to around ~3k before the car really starts to get going.
Keep in mind, a stock converter is about a ~1600 stall, yet the car starts driving at ~500 RPM . But when you step on it, the motor only gets to ~1600 and it has to start pulling (that's why it'll bog, unless you get a stall and let the motor rev higher before the converter REALLY grabs ).
Old Jan 12, 2006 | 11:16 AM
The converter "stalls" the engine until it reaches 3000 like capn said. Basically it means the stall lets the engine free run up to the point of stall (like revving it in neutral), then catches and then starts sending power to the trans. Whole concept behind it is you're getting more power at the wheels initially, then you are when you have a stall at 1600. Since there is more power to be made at 3000 than 1600. With lock up the car will keep the converter locked so it is always transfering power, even at 1000. But if you stomp on it, it unlocks, letting the engine rev to 3000, and giving a harder launch.
On a side note, does anyone know when/what conditions the converter locks up?
Old Jan 12, 2006 | 11:55 AM
Capn Pete's Avatar
Might want to read Rich's sticky on the subject . He may have a little more insight into when lock-up does/doesn't occur .
Old Jan 12, 2006 | 01:52 PM
I know how and everything. But I want to know when the computer decides to lock it up. Not how and why it locks up. Trust me, I've done hours of reading and know. Just wanted to know what parameters the computer sees then goes, "better lock that thing up".
Old Jan 12, 2006 | 10:09 PM
ok, guys............i think i understand it now. Anyways, my vote still goes to me gettin a stall
Old Jan 12, 2006 | 10:34 PM
Bersaglieri's Avatar
Fuddle Racing's Site [One of our new sponsors] has the terms and shift extensions explained well in the FAQ section. I am hoping to get one of their converters by the end of the month when the sale ends, $350 for a wicked converter is a sweet deal IMO. I'd seriously give them a call, the site has their number. Mountain Time Zone. Tell him your setup and what your plans are and he'll get the right stall size made for your application. 3.23's are a good gear, no need to go higher unless you really want to or want to help the drivibility on a larger size cam.
I'd personally look ahead and see where you plan to go with the car. What size cam, juice, S/C or what? Your camshaft and TC work hand in hand, so match those up and youll be happy.
-Dustin-
Old Feb 9, 2006 | 03:58 PM
So are you getting one or what?
-Dustin-
Old Feb 9, 2006 | 05:01 PM
yeah
except i think im going to be getting a 3200 instead.
