Stall on Old 4L60E
Old Dec 4, 2008 | 06:54 AM
SFB767's Avatar
Question Stall on Old 4L60E
What's up guys?
My car has 158,000 well-maintained miles, my trans. has never given me any trouble, shifts perfectly at WOT and normal driving and is always serviced on time.
How much strain and wear would a stall be on my car at this point in its life? Especially the transmission? I think this is the one thing that's missing that holds my car back at the track.
Thanks.
Old Dec 6, 2008 | 01:53 PM
'94 Bad A Z28's Avatar
That all depends on how high of a stall you get. One major factor to the death of a trans is heat. The higher the stall the more heat that is produced. You already have a tranny cooler and that probobly explains how you have 150K+ miles on your trans and you say it works fine.
You have an LS1 car so I wouldn't go any lower than a 3200 stall, I would go with a 3400 since your car is basically stock but no lower than 3200, and to keep the temps in the same area they are now I would add another trans cooler. My car has the stock cooler and 2 big aftermarket coolers. It seems to work very well like that.
Old Dec 12, 2008 | 07:15 PM
LastBreedLS1's Avatar
you should also consider 3.73 gears!! if you do get a stall. than you feel the difference.
Nayr
Mar 3, 2023 08:34 PM
4586
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
SEOJustin
Sep 24, 2015 04:39 PM
