SLP Billet Steel Flywheel
Two quick questions.
-Should/can an SLP billet steel flywheel be resurfaced before swapping to a new clutch?
-The flywheel I have has 30-40k on it and I'm planning on running either the Spec 3 or the Ram Powergrip HD with it. Will this flywheel work with either combo?
also while I have ya here...will the Ram HD survive occasional slick launches with 500ft-lbs?
I am interested in this also. I am looking at the Powergrip but have not heard of anyone running it with the SLP or the Spec steel flywheel. The spec flywheel is only $239 brand new but it looks alot different than the SLP or the stocker. Ram nor Spec will answer weither their products work with other manufactures so no luck there.
The HD is suppose to be up there with the Spec 3+ and Spec 4 so I think it will hold as well as any single disc clutch can.
carguyshu
Jan 22, 2017 11:19 AM
SpeedJunkee
Jun 6, 2015 04:27 PM
