Slave cylinder problem PLEASE HELP
Old Aug 12, 2009 | 10:50 PM
white02z28's Avatar
Angry Slave cylinder problem PLEASE HELP
i keep breaking slave cylinders and i can NOT find out what is doing it i have replaced everything but no change anyone had this problem??? they break the inner tube at the base for some unknown reason.....
Old Aug 13, 2009 | 11:32 AM
rclearyiii's Avatar
Slave Cylinder
The rod will bend if the tip of it when installed in not sitting in the fork indentation. Be sure that your clutch fork is proper seated. Disengage it and re-seat it.
Bob
Old Aug 13, 2009 | 12:35 PM
white02z28's Avatar
I have a 2002 camaro so the slave is bolted to the tranny.. I wish I had the older setup I wouldn't be having this problem
Old Aug 13, 2009 | 12:44 PM
rclearyiii's Avatar
Luck
Ok..sorry that I do not know much on the setup you have. Wish you the best of luck though.
Old Aug 13, 2009 | 07:07 PM
white02z28's Avatar
thanks
im new to this setup also.. thank you for your input just cant find out what would break one slave cylinder right after another. replaced the clutch, flywheel, slave and master cylinder but still broke..
HectorM52
Jul 30, 2017 11:46 AM
Ringmaster72
Mar 19, 2015 03:32 PM
Briah.hood
Feb 17, 2015 02:10 PM
Jason Short
Jan 19, 2015 06:34 PM
siguy
Nov 27, 2014 10:07 AM
