slave cylinder?
Old Apr 13, 2007 | 05:56 PM
Roach02's Avatar
slave cylinder?
Here's the scenario. I'm sitting at a stop light with the clutch fully dissengaged (pedal to the floor) and after the light turns green the clutch is immediatly fully engaged just after slightly releasing the pedal. And if i leave the clutch pushed in after about 10 seconds and let off the brake it actually tries to pull itself. Is this the slave cylinder going out or what?? and how hard of a fix is it?
Old Apr 14, 2007 | 08:05 AM
Capn Pete's Avatar
Either that or the master cyl. going out . There may be obvious signs of leakage around one or the other ... either way, definitely sounds like you've got a problem!!
G-BODYT56
Jan 14, 2022 11:14 PM
94Maroz28
Oct 27, 2015 04:38 PM
jayblev95
Sep 26, 2015 09:44 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
