Shimming the flywheel.
Old Dec 27, 2003 | 12:02 PM
jchevy's Avatar
I recently did a clutch install and my clutch is not fully disengaging. I have already tried bleeding the hydrolics and even replaced them with the new GM kit. I had the flywheel resurface and im thinking this might be why its not disengaging.
Can i buy shims to shim it? What is the thickness of a new GM FLywheel, i dont know how much was machined off so i will need to mic it.
Old Dec 27, 2003 | 07:39 PM
OBE1 95Z28's Avatar
I would think that if the flywheel was cut too thin you'd have a problem with the clutch slipping, not a disengagment issue. It sounds more like you're not getting enough travel out of your hydraulics. Is the plastic "cap" still on the end of your slave cylinder rod (where it mates to the fork)?
Old Dec 27, 2003 | 09:05 PM
Heatmaker's Avatar
Advanced Member
I have the exact same issue it's the flywheel.....funny I did the exaxt same things he did too....
Old Dec 28, 2003 | 01:52 PM
jchevy's Avatar
heatmaker,
With your car does it sometimes go into gear easier than others. Mine is kind of an intermintent problem, sometimes it will slide into gear with only a small effort and most of the time its a real pain. Its only when im at a complete stop. Other wise it shifts ok.
Old Dec 28, 2003 | 02:45 PM
Heatmaker's Avatar
Advanced Member
Yes, mine does the same thing. The gears are easy to get into and then sometimes they might need a little "umph" to get into. My clutch holds fine though but my pedal has no spring in it. Plus my reverse isn't happening at all. I did the exact same things you did. Got a new GM Hydrualic kit too. I can kind of guarantee that it's the flywheel on my car. WHen I took it off it had heat marks and all on it. My rear main seal was leaking. So I think they had to take allot off to get it clean again. But it was too much...and now I'm f3ked.
Old Dec 28, 2003 | 03:14 PM
jchevy's Avatar
Yeah, mine was hot spotted pretty badly also. No im trying to figure out the thickness of a new flywheel so i know what size shim i need.
Old Dec 29, 2003 | 03:23 PM
surfinmud's Avatar
I found an old post which said a new flywheel is 1.828"
Old Dec 29, 2003 | 08:03 PM
jchevy's Avatar
Thanks much for the info.
karpetcm
Sep 29, 2015 10:08 AM
karpetcm
Aug 14, 2015 03:02 PM
realistyc
Jul 28, 2015 07:32 PM
achipfef
May 5, 2015 10:20 AM
lifesun
3rd Gen / L98 Engine Tech
Jun 24, 2002 11:53 AM
