shifting ?
Old Sep 27, 2009 | 08:58 PM
fastfox's Avatar
shifting ?
do people who have automatic trans manual shift it,are just leave in drive and let the computer shift.i hear it shifts slower if u shift than let the computer shift.
Old Sep 28, 2009 | 12:05 AM
LearJet's Avatar
Don't shift it, let it shift itself. I have heard that launching in manual 1st and then going to drive is beneficial due to more clutches being engaged during launch. Other than that the car will be much more consistent if you let it shift itself and your trans will hold up better.
Old Sep 28, 2009 | 12:20 AM
The Untouchable's Avatar
it also depends on how much wear your trans has too , sometimes it can hang in a gear a lil bit longer when they have alot of miles on them
Old Sep 28, 2009 | 08:49 AM
fastfox's Avatar
thats what i have been hearing bout the wear and tear, do u leave it in 3,or but in overdrive and let it shifit.
Old Sep 28, 2009 | 05:11 PM
Z-RATED94's Avatar
Let the computer do the work. I start off in 3rd until the 1-2 shift happens than shift it into overdrive for a better 2-3 shift at the track. What I'm doing is what was recommended by some trans people for the best holding power as LearJet was explaining. Before I tried this the trans was not wanting to make the 2-3 shift when i was using the nitrous. I don't expect the stock trans to last long on the bottle but at least for now it's making the 2-3 shift. One other thing recommended was to slightly (1/2 quart) overfill the trans.
Old Sep 28, 2009 | 05:39 PM
fastfox's Avatar
just dont feel like it shift,right the car is not stock,and i hear its good for a stock car do let the comptuer shift but if car is tune and performance it dont matter.next time out i do plain on trying both ways.
Old Sep 29, 2009 | 06:45 AM
AL SS590 M6's Avatar
Moderator
When you mod the car you correct the shift points in the tune then let the computer do it's job. Look at my car in my sig. It shifts itself, put it in 3 and punch it. Variations in my et from round to round are .00x if that when the weather is stable.
Old Sep 29, 2009 | 02:51 PM
fastfox's Avatar
i will try both of them we do lots of street racing,dont go to track much.
Old Sep 29, 2009 | 08:28 PM
fastfox's Avatar
car did real good with leaveing it in 3 and let computer do the work.fills alot stronger too,thanks for all the info.
Old Sep 29, 2009 | 10:45 PM
What you people are probably feeling when in manual mode is the extra line pressure the computer provides vs. normal mode. It's especially higher in 2nd gear. Even part throttle shifting is going to feel harder.
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
marlar98
Sep 19, 2015 07:53 AM
