shifter help
idk if this is the correct forum but i just got some new d/r on and went to test them and when i launched i was holding the shifter and if you pull hard on it, it goes drom od back to drive without using the button? what causes this, worn out part? can anybody give me an answer today...goana try to go to the track tomaro
thanks daniel |
Re: shifter help
took a long look at the mechanics today and figured it out...the metal piece that connects to the button slides along a half metal and half plastic piece, where the lockout and everything is at...well on my car the metal and plastic arent flat across so i trimmed the plastic some in the groove for neutral and overdrive and it works fine
thanks |
