Replaced broken slave cylinder. Clutch not going down to floor.
Old 05-23-2015, 05:50 PM
supercharged94Z28's Avatar
So I was driving yesterday, shifting normally around 35 mph and all of a sudden I heard a noise, like a chatter or bang and the clutch went straight to the floor and was inoperable. Low and behold, the slave cylinder was dangling and broke off the 2 bolts. I got a new slave cylinder, bled it out but after installing it, the clutch will not engage. Outside the car, while pressing the slave cylinder by hand, and having someone push the clutch, it works properly and goes all the way to the floor. My question is, how loose is the fork supposed to be? Cause it's really loose and I can push it back and forth with no effort at all as if it were blowing in the wind. I would think it would need to be solid to keep pressure on the slave cylinder. Any one have any input? Thanks.!! It's a t-56 6 speed transmission. Just had a new clutch, input shaft, throw out bearings installed about 8 months ago.
supercharged94Z28 is offline
Old 06-02-2015, 03:32 PM
97WS6's Avatar
Re: Replaced broken slave cylinder. Clutch not going down to floor.
Sounds like either your clutch release fork or the Throw Out Bearing(Release bearing) or both, are FUBAR'd.
Looks like it's time to drop the tranny and bell housing and check out the damage.
97WS6 is offline
Ringmaster72
03-19-2015 03:32 PM
BPS
9
03-05-2015 10:51 PM
HectorM52
01-30-2015 11:08 PM
Jazsun
12-29-2014 12:14 PM
Quick Reply: Replaced broken slave cylinder. Clutch not going down to floor.
