Removing axels
Old Apr 23, 2007 | 06:54 PM
Geezer powered's Avatar
Removing axels
Ok I got the diff cover off, so hoe do I remove the axels. Tried searching but could'nt find a step by step answer. I know use the search button but hey this is a meeage board not a search board. Thanks in advance......
Old Apr 23, 2007 | 07:04 PM
VK's Avatar
VK
Push the wheel in, then in the center of the carrier the axle will protrude maybe 1/2" there will be a C-clip you simply have to pull off and then the axles will come right out. (there is a c-clip on each axle)
Old Apr 23, 2007 | 07:06 PM
VK's Avatar
VK
oops, forgot to tell you to remove the cylinder from the center of the carrier before you can push your axles in
Old Apr 23, 2007 | 07:08 PM
cylinder? How do you get that out?
Old Apr 23, 2007 | 07:14 PM
VK's Avatar
VK
turn the carrier until one of the ends faces you, then tap it out
Old Apr 23, 2007 | 09:23 PM
93v8clone's Avatar
ummmm no it has a 8 mil headed bolt that holds the alignment pin in pull the bolt out and then lightly tap the pin it will come out once the pin is out push the wheel in and use a magnet and a small pick to remove c clip install is reverse
Old Apr 23, 2007 | 11:16 PM
VK's Avatar
VK
sorry, didn't think i needed to get extremely detailed.. if you can't figure that out.. you shouldn't be fooling around in there anyways
Old Apr 24, 2007 | 03:33 AM
revtime's Avatar
If your going to answer questions be as thorough as possible. The guy could be out there beating on the carrier with a sledge destroying his rear end because you neglected to tell him about that bolt.
These forums are to help people out not frustrate them more.
Old Apr 24, 2007 | 09:35 AM
VK's Avatar
VK
Cool it man.
If you have to sit there and explain every last detail on how to do anything on here, no one would post answers anymore and all we would have is people asking questions no one wants to answer. Like i said, if you don't have the know-how to notice the VERY simple things, you should not be taking that stuff apart. They are going to put it back together wrong, forget to tighen a bolt and kill themselves when it comes apart going 60MPH down the road.
Old Apr 24, 2007 | 05:57 PM
Thanks for the help guy's, did'nt mean to stir anything up. I was alright once I turned the carrier. I did notice the 8mm bolt. I had it apart and put together with ne studs while you guy's were still going back and forth hehe. Thanks again........
Old Apr 24, 2007 | 08:27 PM
93v8clone's Avatar
good
Old Apr 25, 2007 | 04:07 AM
revtime's Avatar
I apologize if I came off a little harsh.
I rely on these forums alot and just don't want anyone to hurt themselves or their car from bad info.
Old Apr 25, 2007 | 08:21 AM
VK's Avatar
VK
It wasn't bad info, it was perhaps incomplete or lacking detail.
Some things are better off to the professionals.
greenzee28
Sep 25, 2015 04:29 PM
Jake Bialke
Sep 24, 2015 11:31 AM
wbspoon
Sep 19, 2015 08:12 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
