Reducing shift pressure
Hi, I have a B&M shift kit installed in my transmition and like the harsh shifts at WOT but it is annoying at low throttle, slow speeds, and stop and go traffic. I have LT1 edit so I reduced the shift pressures at lower TPS values by half and that has helped alot though I think a little bit more would be good. I want to check if this is a potential problem for my transmition? Does the reduced pressure cause any engagement problems? How low can I go? I have AutoTap aswell to keep tabs on everything. I'm not sure if this would be better to post in the computer programing area... Any insite, past expirience would be awesome. My goal is to keep the quick shifts at high throttle and make it softer at low throttle. Thanks!
Conor Musgrave
97 LT1 /A4
Conor Musgrave
97 LT1 /A4
carguyshu
Jan 22, 2017 11:19 AM
stockssn2o
May 25, 2015 08:54 AM
Apr 16, 2015 09:57 AM
