Rebuilding the Pro 5.0 Shifter?
Old Sep 18, 2010 | 12:49 PM
OBE1 95Z28's Avatar
I've noticed that my 10 year old shifter doesn't have the centering spring action it had when new. Anybody ever rebuild theirs? I just emailed partspro@live.com who looks to be the reps/manufacturer's of the Pro 5.0 shifter to see if they have a rebuild kit.
Old Sep 18, 2010 | 04:14 PM
Colin's Avatar
No, but I'm curious. The only mod on the LT1/T56 powertrain in my Vega is a Pro 5.0 and I've heard they get sloppy after awhile. It'd be cool if a rebuild kit is available.
Old Sep 20, 2010 | 01:44 PM
OBE1 95Z28's Avatar
Pro50.com sells replacement springs (2) to rebuild the shifter. $25 (min purchase); rip-off price but still cheaper than a new shifter. Pro50 has a very limited product line so I didn't find anything else to buy to meet the $25 minimum.
Old Sep 21, 2010 | 06:18 AM
AL SS590 M6's Avatar
Moderator
Before I did that I'd go to a local fastner company like Fastenal, Grainger, ect. and find some springs that will work.
Old Sep 24, 2010 | 02:50 PM
OBE1 95Z28's Avatar
It's going to be hit and miss to get the correct spring rate. Not looking to rebuild it multiple times.
Old Sep 25, 2010 | 07:27 AM
Moderator
It's not a Swiss watch. Going with the same wire dia. and number of winds will get you close. You could even step into a machine shop with the springs and have them check out the spring rate before you install.
Or just spend the money for them from Pro.
Old Oct 27, 2010 | 03:37 AM
Ghostrider001's Avatar
My Pro 5.0 is still serving me well in my 99 SS. It's been on there for like 10 years.
Old Nov 3, 2010 | 06:04 PM
97FormulaWS-6's Avatar
Re: Rebuilding the Pro 5.0 Shifter?
McMaster Carr or Grainger and grab some springs that are the same physical dimension and replace them. I grabbed a few different rates when I did mine years ago and found a force I liked that worked. It was actually stiffer than the shifter in stock form, but I liked it better.
Old Nov 12, 2010 | 02:48 PM
OBE1 95Z28's Avatar
I rebuilt mine with the Pro50.com springs; could not tell any difference! I noticed that the springs sit on metal disks that interfaces with a cross rod mounted to the shift lever. I had a friend machine me a couple of matching disks that i used as spacers to increase the spring force. Worked like a champ!
ducttape1975
Jul 10, 2015 06:29 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
