rearend: what breaks
Old Oct 19, 2004 | 04:15 PM
sp33d33ss's Avatar
What usually breaks in a 10-bolt when it goes out? axles? gears? I've talked to 2 people about this, one says it's usually the axles and another says that it's the bearings and things. I don't want to get a 12-bolt right now, so if I could install some new axles and be ok then that would be cheaper than a new rearend. also what could I do to strengthen the old 10-bolt if I keep it?
FYI: 3.73's, auto, bolt-on's, soon to add slicks...
Old Oct 19, 2004 | 05:49 PM
n2ceptor's Avatar
Re: rearend: what breaks
Usually gears and the limited slip(aka; posi unit).....
Old Oct 19, 2004 | 06:10 PM
Z95m6's Avatar
The ring gear is usually what breaks. We have 7.5 inch ring gears. That is why people up grade to 8.8's, 12 bolts which are around 8.75ish, and 9inch's which are obviously 9inch ring gears.
Old Oct 19, 2004 | 06:14 PM
atljar's Avatar
What doesnt break would be the better question.
93 RedBird
Nov 15, 2015 08:24 AM
Bxlt1
Sep 29, 2015 03:18 PM
Aug 17, 2015 09:50 AM
Cam's maro
Aug 11, 2015 07:45 AM
