Rearend Problems?
I only have the right tire spinning now, leaking from pinion yoke, and also the drivers side axle...oil all over inside of rim.
What all do I need to fix this?
Found alot of info on replacing the pinion seal but what about the diff and how do you go about stopping the leak from the axle.
Well if your car is only spinning one tire and its a posi(limited slip), I would have to say your posi (limited slip) is worn out. The axle seal can be replaced fairly easily. You need to remove the axle and remove the old seal and put a new one in. Make sure to check the axle to make sure there is no groove where the old seal was running on. If there is then the axle will have to be repaired or replaced.
ddr698
Jan 31, 2015 10:58 AM
Speeds8erM-1
Jul 28, 2002 06:18 PM
