Rear End Trouble
Old May 6, 2005 | 11:32 AM
DonJuanTA's Avatar
Question Rear End Trouble
i was replacing my brake pads on the right rear wheel of my TA and when i removed the caliper i pulled slightly on the brake rotor and the whole AXLE shaft slid out of the axle housing. my car has 160000 i believe it just has to many miles and that the C clip just broke off anyone have any suggestions on what the problem is or any quick fixes
Old May 6, 2005 | 11:57 AM
Compstall's Avatar
Re: Rear End Trouble
I would say it's pretty obviousl the retainer came off inside. I would take the cover off the rear and take a look to see what else is awry back there.
Old May 6, 2005 | 05:45 PM
respectirocz's Avatar
i say that one benefit to disc brakes over drums
if u had drums, u would have lost the entire wheel and axle when the retaining clip fell/broke
but your caliper kept ur axle together
hopefully the clip fell out and didnt do much harm in the case, if its intact u can find out why it failed, and replace it
if it did damage to the ring and pinion, assess the damage make sure u dont need to replace those
if the clip is there and u broke an axle shaft
well
u should have known already, and your posi (if equiped) has been overworked
Old May 7, 2005 | 12:13 PM
DonJuanTA's Avatar
Question Re: Rear End Trouble
the axle shaft im almost positive isnt broke cause when i pulled on it the axle rotated a little like it was unmeshing with the gears and when i put it back in i had to rotate it clockwise like a quarter turn so i would meet up with the gears. i was planin on takin the coverplate off this weekend but dont know where to get a C clip advanced doesnt have it any suggestions?
Old May 7, 2005 | 12:30 PM
Compstall's Avatar
Go to any shop that does rear ends. Quite a few 4x4 shops do this too.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
