rear end question
Old Feb 13, 2011 | 08:56 AM
shawngamblez28's Avatar
Question rear end question
i found a ford 9in cheap but its out of 3rd gen will it fit n my 4th gen im not sure if it will fit rite n or not let me know thanks for ne help
Old Feb 13, 2011 | 10:16 AM
Re: rear end question
Should be a direct bolt in, but its going to be at least 3" narrower than the 4th Gen rear axle assembly (some say the difference is 4"). You would need to run wheels with near "0" offset, compared to the stock 4th Gen 50-55mm offset wheels.
Old Feb 13, 2011 | 12:46 PM
Procharged94Lt1's Avatar
I'm not a big fan of them personally but you could also get some bolt-on spacers to set the wheels back out where they are supposed to be if you didn't want to go the route of getting new wheels.
I know a lot of people run them and have no problems, but to me its just one more thing you are putting in the mix that has a potential to give you problems...
What is 'cheap' if you don't mind me asking?
Old Feb 13, 2011 | 01:37 PM
700.00 minus brakes and torque arm bracket
Old Feb 13, 2011 | 01:40 PM
thanks for the info greatly appreciated
Old Feb 13, 2011 | 11:55 PM
You should be able to get a bracket pretty easily for the brakes and run the stock brakes- The torque arm bracket will be a little harder to get, but a call to Moser or Strange and hopefully they can get you what you need.
oldschool
Feb 9, 2016 09:21 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
