Rear end noise
Old Jan 28, 2011 | 02:35 PM
chevy_dude97's Avatar
Rear end noise
Ok so I have been dealing with this real annoying noise coming from the rear end. It would sound like tire rub on right hand turns between coast and throttle. If I take it out of gear I still get same noise, it seems to only go away when I give it gas or if I idle around right handers. does not make any noise turning left. I have looked under the car around the tires and no rub marks ect... I have opened up the rear diff, and everything seems good with only minor metallic goop on the magnet. I did not see any chips on any sides of the teeth and the wear pattern looks good. when I turn the wheel I hear a slight scratch inside the torsen worm gears. Could this be the source? IDK I changed the fluid and slapped her back together and still the noise.
Old Jan 28, 2011 | 05:25 PM
Kevin Blown 95 TA's Avatar
Re: Rear end noise
Do you maybe have a bad wheel/axle bearing?
Something else they do is that the c-clips grind into the diff a little and increase the clearance which lets the axle move in and out a bit so the rotor could be grinding on the caliper or something - you might have to look around a bit for clues.
Old Jan 29, 2011 | 01:56 AM
Re: Rear end noise
is this normal for a 54k car? to have the c-clips wear into the axle? Ill have to pull the wheel tomorrow
Old Feb 1, 2011 | 05:23 PM
Re: Rear end noise
would c-clip eliminators solve the problem if they are it?
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
