Rear end gear change....Experts Inside!!
Old Jan 10, 2006 | 03:07 PM
patricktroy's Avatar
Want to change the gears to 3.73 on the stock rear end on my 1991...is this the right one to get?
http://www.jegs.com/webapp/wcs/store...tegoryId=26297
part # 555-60010K
Old Jan 10, 2006 | 03:38 PM
87DJP2001's Avatar
Re: Rear end gear change....Experts Inside!!
No rear gear swap is easy and more so if its the first one.
You didn't give any info on what you have now to know if that Jegs kit will work or not. You need to know if your rear is a 2 or 3 series carrier to start with before seaching for parts.
Old Jan 10, 2006 | 03:48 PM
Well, the best I can tell you it is a stock rear end of a 1991 Z, so I beleive it is a 2.73 gear ratio, and I want to go to 3.73 ring and pinion.
So, with the best internet knowledge, I need a 2-series carrier, yet I have found out that mine is a 7.625", where Jegs is a 7.5" kit, but GM blacklash is like .004 to .010., so a 7.5 is a 7.62.....right or wrong??
Old Jan 10, 2006 | 05:54 PM
87DJP2001's Avatar
Just make sure you do your research....7.5/7.625 grars are the same per GM.
Old Jan 10, 2006 | 06:14 PM
OK thanks for the info! Hate to spend $ on the wrong parts!
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
