Rear end diff lube
Rear end diff lube
I want to change my diff lube this weekend. I bought 2 bottles of the Mobil 1 Synthetic 75w-90 and a bottle of Trans-X posi-trac limited slip gear oil additive. Just wondering how much Oil I will put in with the 7oz posi additive?
Re: Rear end diff lube
Put the car on jackstands so it is level. Fill it till the fluid starts coming out of the fill hole. My manual says 3.5 pts.
About the posi additive, I read of people having issues when not using the GM additive, such as the rear making noises when turning.
Here's a link for changing fluids.
http://www.bfranker.badz28.com/fbody/lubeoil.htm
I just changed mine a couple of days ago, used up 2.5q of 75w-90 and some lsd/posi additive which i bought from autozone and my diff dosen't make any sounds while driving straight or turning.
As far as volume goes, I just repeated what was in my owners manual. What does yours say?
My '98 S-10 has a limited slip, but the manual calls for no additive. I assume it has a Zexel.
I have used synthetic fluid in my Auburn with no additive and had no issues. I have read on this board where people have. That's what I was conveying.
My owners manual told me to use the GM lsd additive, but now your saying i don't need to use it i have no problem with that if its true since a bottle of that stuff is 15 bucks.
http://www.torsen.com/general/genera...difier%20added
