rear end change.
rear end change.
I have a 95 T/A w/auto 4 and the 2.73 rear posi. What ring and pinion can I change to w/o going to any other changes. Can I do a 3.42 using the same unit? Thanks. Larry.
Re: rear end change.
Yes just make sure that you get a ring and pinion that say they are intended for a 2 series carrier. I know summit carries them, so should most other aftermarket vendors. Specifically, stock 3.08 and below = 2 series, 3.23 and up = 3 series.
