Rear end
Old Apr 5, 2013 | 08:14 PM
Gregdonna's Avatar
Rear end
Hi I'm new and like a little help please I have a 92 Z28 350 TPI and it has a 323 rear end and I like to swap it out to a 373 what I like to know is what year camaro's rear end can I use. I have disc brakes all around and I want a posi also.
Old Apr 7, 2013 | 08:16 PM
Gregdonna's Avatar
Re: Rear end
No one can tell me what year rear end will fit in my car why is this hard to believe. Ok or tell me what parts do I need to make it a posi and a 373 and the easiest way to go about this. I know I have to do a new ring and pinion but what else will I need.
Old Apr 7, 2013 | 08:21 PM
BOTTLEDZ28's Avatar
Re: Rear end
Any 3rd gen that had the disc brake option from the factory will work. 3.73s were never offered as a gear option on these cars. 3.42 was the best you could get in the 10 bolts. If you want 3.73s then you must buy the gears and install kit and have someone install them. Are you running the stock wheels? if you have intentions of running a 4th gen fbody wheel in the future then you can install a rear end from a 93-97 Fbody car and you wont need to run 2" spacers on the back. Those rears are 4" wider overall.
I have a 4th gen posi rear with completely rebuilt and painted disc brakes for sale. it has 3.73s in it already. Shipping may cost a bit but you are going to pay either way.
Old Apr 7, 2013 | 09:54 PM
Re: Rear end
Here is a 2-part article on strengthening the 10-bolt rear. Although it describes a 4th Gen rear, other then the fact the 4th Gen rear is 3" wider than the 3rd Gen rear, the parts (particularly the posi carrier) all mostly the same.
Are you sure your current rear does not have a posi? Check for RPO G80.
Here's an Eaton posi, about $550.
Eaton limited-slip differential - PN EAT19599
Torsen T2 Differential For Your 10-bolt Rearend - High Performance Pontiac Magazine
Fourth-Gen 10-Bolt, Part 2 - High Performance Pontiac Magazine
If you plan to go up in HP/torque, consider a used 12-bolt rear from Strange or Moser.
Old Apr 7, 2013 | 09:55 PM
Gregdonna's Avatar
Re: Rear end
I'm going to be running a set of Corvette 19.10 wheels and 18.8.5 in the front
Old Apr 8, 2013 | 03:33 PM
Gregdonna's Avatar
Re: Rear end
I found a 1992 rear end but it has drum brakes and not disc but its a 410 posi can I just swap over the disc brake stuff or just take the gear and pinion out along with the pumpkin and put it in my rear end.
Old Apr 8, 2013 | 04:53 PM
Skedaddle's Avatar
Re: Rear end
You are going to have some major issues with the 19x10" rear Corvette wheels, if they are the 79mm offset (OEM) wheels. They sit so deep in the wheel wells of a 4th Gen with it's wider rear axle assembly that they need 1.25" spacer/adapters. With a narrower 3rd Gen rear, you would be looking at spacing the wheels up to 3.0 to 3.5" from the axle hub flanges. Finding a 4th Gen rear would make more sense in that case.
All 4th Gen V8 cars have a rear axle with disc brakes and a limited slip rear.
Check the "sticky" posts on the Wheels and Tires forum. I think there is a thread regarding C6 wheels on a 3rd Gen.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
