ready to burn car after clutch install
Old May 5, 2006 | 10:35 PM
chevy1963's Avatar
Ok, is there some sort of special trick i'm missing to the the clutch form on the TOB!!! I have taken it about( the tranny) twice now everything looks good to go. I then push on the pedal and it goes to the floor, I try it again and hear cluck. I pull theslave and the fork comes off the TOB.
Old May 6, 2006 | 03:27 AM
firebird84's Avatar
Re: ready to burn car after clutch install
you need to bleed the system because it is hydrolic. if you have not opened the system (which you have to do to pull it) then you have a leak.
Old May 6, 2006 | 12:28 PM
chevy1963's Avatar
Whats the cost of replacing the master?
Old May 6, 2006 | 12:43 PM
cmroSS97's Avatar
[QUOTE=firebird84] if you have not opened the system (which you have to do to pull it) QUOTE] you don't have to open the system to remove it fwiw
Old May 6, 2006 | 01:49 PM
Stoopalini's Avatar
Sounds to me like you're not getting the fork all the way into the TOB.
Even with the slave cylinder removed, the fork should not just fall off the TOB. You typically have to grab the fork and pull it down to disengage it; if it's engaged fully.
Thomas.
Old May 6, 2006 | 01:55 PM
cmroSS97's Avatar
Thomas.
i agree with this.
Old May 6, 2006 | 04:56 PM
chevy1963's Avatar
Ok I have now got the fork on the TOB. Now the master is leaking Whats the cost of thw whole assembly?
Old Oct 7, 2006 | 07:26 PM
94EvilZ28's Avatar
i just paid 213 for the full assembly with new resivour, slave and master...but IM having the same problem
Old Oct 9, 2006 | 06:57 AM
chevy1963's Avatar
I got it figured out. It was a bad slave unit. Just on a side note if you need any gm parts look at samtaylor or vandevere dealerships on here. I just bought a master and slave complete unit for a friends car for 130.00 del.
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
CobraEatr
Jul 24, 2004 11:37 AM
