questions about tranny
Old Sep 10, 2005 | 09:12 AM
red 95 z28 lt1's Avatar
i just recently got my engine together and in the car. I had my 4l60e rebuilt about 6k miles ago b4 my engine rebuild now i have a trans temp gauge in the car now since i put the motor in and i noticed when sitting in traffic the gauge goes up to 240 and higher but if im crusing it slowly goes down. now i dont have any aftermarket trans cooler but i have a 2600 stall converter. tranny shifts fine also. is this normal and will a aftermarket cooler help. i was also told that the stall converter will raise the temp too. Is this true?
Old Sep 10, 2005 | 09:17 AM
Red on Red WS6's Avatar
Re: questions about tranny
When I put in my converter I was running around 220 driving around in the city. With a supercooler I now run 160 to 180 in the city 150 to 160 highway. Did you use the port on the tranny to plug in the sensor?
Old Sep 10, 2005 | 09:35 AM
Z-RATED94's Avatar
Even a stock trans would benefit from a trans cooler, let alone one with a aftermarket stall. You need to put one on right now, not tomorrow, not this evening, not after lunch, right now!
Old Sep 10, 2005 | 10:45 AM
96capricemgr's Avatar
Sounds like you bought a crappy converter. I had a crappy 2600 Level 10 9.5" and it ran HOT, my current 2800 Edge runs cooler and drives better.
240 is too hot additional cooling is a good idea, I would recommend a B&M or Tru-Cool (they are made by the same supplier) with the "thermostatic bypass" feature which will help aviod overcooling and help warmup, because random cooling is not a good thing either you want the tranny to be at least 160, automotive fluids are not designed to work at room tempature they need a little heat.
Old Sep 10, 2005 | 11:28 AM
Yeah, I got to say I am very pleased with my Edge converter also.
Old Sep 10, 2005 | 05:16 PM
no its welded into the pan, is it hard to install a tranny cooler?
Old Sep 10, 2005 | 09:25 PM
Z28Nut's Avatar
It's not technically difficult but it was a PITA to get the zip-ties through the condensor and radiator fins to hold the aftermarket cooler on. You need to splice the cooler into the existing lines to the stock cooler. The B&M cooler I got had pretty good instructions and it took about 1.5hrs. I ran the fluid through the aftermarket cooler first, then through the stock cooler in rad. so the fluid wouldn't over cool.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Sergio
Jan 27, 2016 04:27 PM
importkiller94
Jan 17, 2015 09:03 PM
nballisru
Dec 14, 2014 05:01 PM
mattszm6
Dec 14, 2014 07:09 AM
