Question for people with S60
Just wondering what all you needed to modify to make this puppy fit. I know the Strange 12bolt is a direct bolt-in down to LCA relocation brackets, I was wondering if the S60 was the same except for being a little longer in the middle meaning the driveshaft will have to go and a couple aftermarket torque arms need trimmed, anything else you had to do to bolt it in??
that should be it! Ill let you know after this weekend, Im test fitting mine in and welding in some relo brackets. Im hopin for a good clean install! I bought stranges chrome moly driveshaft as well as it is 1.6 inches shorter...
Hurin
Dec 13, 2014 07:38 PM
Z28Wilson
Aug 1, 2002 04:27 PM
