Problems with transmission
Old Jun 20, 2005 | 08:01 PM
jsz28's Avatar
Ok i just did the a4 to m6 swap and have a couple of questions. First of all i started the car to see if it would go into gears. The clutch pedal would not go in so i turned the car off and checked the slave cylinder. Well took it off and that clutch fork is lose i can move it by hand from back to front. My question is whats wrong with it and do i have to take the transmission back out. Need help bad. Dont know whats wrong with the fork
Old Jun 20, 2005 | 08:03 PM
madwolf's Avatar
Re: Problems with transmission
You should be able to move it around a little bit, but if you push it with you finger, it should be level with the opening on the bellhousing. If you can push it in further, then you probably don't have it in right.
Old Jun 20, 2005 | 08:06 PM
jsz28's Avatar
then more than likely it is not in right. How does it go on, my brother put it on for me and i dont know if it is right or not. What does it hook to.
Old Jun 20, 2005 | 08:19 PM
madwolf's Avatar
It hooks up to the throw out bearing on the pressure plate.
Take a look here. You can see how mine is installed in the background.
Old Jun 20, 2005 | 08:25 PM
madwolf's Avatar
A couple more pictures: (blurry, but you can see what kind of movement is normal for a properly installed fork. You can pull it out a bit, but it shouldn't go in more than you saw in the first picture)
Picture 1
Picture 2
Old Jun 20, 2005 | 08:31 PM
jsz28's Avatar
Ok thats my main problem then. I will have to fix that. Also i got a spec stage 3 clutch. One more question is can that clutch only go in one way. Because i dont know if he put that in right or not. It was a used clutch and both sides looked fine to me.
Old Jun 20, 2005 | 08:34 PM
madwolf's Avatar
That's what I have too. The side sticking out should be facing the engine.
Old Jun 20, 2005 | 08:40 PM
jsz28's Avatar
Well its in the car right now with the transmission bolted to it. So how can i tell from that. So i guess i have to take everything back out to see right?
Old Jun 20, 2005 | 08:45 PM
madwolf's Avatar
I would try to install the fork correctly first. If you still don't get any results, then I would be looking into pulling it out. Is your hydraulics new? If not, did you bleed it?
Old Jun 20, 2005 | 08:49 PM
jsz28's Avatar
Im going to try the fork first. What is the best way putting it on without taking the transmission out.
Old Jun 20, 2005 | 08:51 PM
madwolf's Avatar
Pull it out first, then play with it until it goes in all the way and it looks like in my first picture. Did you put any grease on its ends before putting the tranny in?
Old Jun 20, 2005 | 08:58 PM
jsz28's Avatar
So you can take the clutch fork out without taking the transmission out and yes there is grease on it.
Old Jun 20, 2005 | 09:01 PM
madwolf's Avatar
You don't take it out all the way, just grab the end and pull it out in the same direction (away from the bellhousing, not towards you). Then once it's out, you want to install it by pulling the end some towards you so that the other ends go on the bearing, then you move it around and try to push it in until you get it to look like in that first picture.
Old Jun 20, 2005 | 09:05 PM
jsz28's Avatar
Thanks for the help. Im still new to this stuff. So i can back the transmission out about an inch pull back the clutch fork and slide it onto the pressure plate where the throwout bearing is at? Thats what im gettting from this. Im sure you know this better than me
Old Jun 20, 2005 | 09:07 PM
madwolf's Avatar
I was able to do it without disconnecting the transmission. Give that a try first.
