Prescision GEars Question???
Old Jan 20, 2007 | 08:45 PM
hogs's Avatar
Just wonder if any here have used the 373: gear sets and like them from this company or any have plms. with them etc.??
Old Jan 20, 2007 | 08:55 PM
jay_lt4's Avatar
very good quality gear, i have installed many sets of them in cars and trucks
Old Jan 21, 2007 | 04:45 PM
hogs's Avatar
gears
So you have installed many of these gear sets with no plms. I have heard of a few that had plms with them??
Old Jan 21, 2007 | 05:18 PM
jay_lt4's Avatar
i have only had 1 bad set they were for a gm 8.5" 4.11 ratio,, they installed perfect, the guy drove them for 1200 miles then they started making noise, i removed them and inspected them and they were wearing like they didnt get hardened enough, i called randy's ring and pinion and they said yes they have had 4 other cases of this only in the 8.5 4.11 ratio, they sent another brand and all was good
other than that(they knew they had a problem with them),, they are a very good gear, the set up is almost always dead on with the stock pinion shim and correct backlash
i have installed many, many sets of gears and different brands for people and i prefer the precision over the other brands
there install kits are very good also, they have a new style adjustable side shims to get the backlash/side bearing pre-load right on easily
Old Jan 22, 2007 | 09:10 AM
hogs's Avatar
Thanks for the reply so If I go with 3:73 all should be okay then, anyone else got anything to say about Precision Quality or lack of??
ChrisFrez
Feb 15, 2015 07:49 AM
ChrisFrez
Feb 1, 2015 08:26 AM
ChrisFrez
Jan 25, 2015 08:06 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
