poly urathene mounts suck!!
well just got it installed, and man, tons of vibration.....
whats the deal here? either the tranny mount created alot of vibration or its my clogged cat making most of it....
only makes BIG time vibration around 4-6k rpms...
any clue?
Randy
any clue?
Randy
Re: poly urathene mounts suck!!
Yup, that's a poly mount for ya! I bought one for my '02 WS6 I used to own, hated it so much I put the stock one back on and sold the poly mount for $10 to someone local.
Get a 1LE solid rubber mount. The factory mount is hollow rubber to dampen vibration. Poly mounts are pretty harsh and a little taller. That alone may have changed the driveline angle enough to make an already slightly out of balance shaft a little more noticeable. The 1LE mount is plenty stiff, won't break easily and the vibrations are minimal.
I had the Energy Susp. poly mount. The vibration wears off after a month or so, but since mine was used and was already broken in, it wasn't that bad. Or I just got used to it...and it made it feel a tad bit quicker, too.
Funny, the guy I bought mine from had the same complaint, his wife acutally didn't like the vibration in the car. But I thought Camaros were suppose to make you feel that way...
I have the same freakin problem. If I put the car in gear, I will hear a vibration come from the rear of the car and stay until I give the car gas. I have a energy suspension mount BTW.
While you may get more responses here they might not be as good as you would get in the drivetrain section
I suppose you haven't done a search either?
If you know what to install and/or how to install it, the polyurethane tranny mount is a good thing to have, IMO.
