Poly Transmission Mount
Old May 16, 2004 | 07:01 PM
  #16
bunker's Avatar
No I have an LS1 alluminum DS.
Old May 16, 2004 | 07:26 PM
  #17
93Z4ME's Avatar
What brand are you guys using, I've been calling Energy Suspensions for over two years now and they keep saying they're still working on making a correct one for our cars. Well at least they are still pretending like they are serious about it.
Anyone use the Prothane's? Are they made for our cars dimensions?
Old May 16, 2004 | 07:30 PM
  #18
RedHottG2's Avatar
For the price, the Energy Suspension mount is well worth it IMO. I used one in my 93 Z28 and one in my 95 Formula (both M6s). I was very happy with the way both cars feel after the install.
Old May 17, 2004 | 12:00 PM
  #19
curly's Avatar
I had the ES mount and took it off after my teeth chattering at higher speeds for too long. I also had the aluminum driveshaft and still had BAD vibration. I went to a LS1 tranny mount and really like it better. Just my .02.
I'll sell the ES mount cheap if anyone wants one, it's sitting in a box on the shelf.
Old May 17, 2004 | 12:37 PM
  #20
ping0317's Avatar
Can you tell me the LS1 Trans Mount # please?
Old May 17, 2004 | 07:13 PM
  #21
curly's Avatar
The part# I have is 22174970 but you will probably want to verify this with GM. Hope this helps.......
Old May 17, 2004 | 07:40 PM
  #22
S8ER95Z's Avatar
I went with the Poly mount and I didnt notice any difference in vibration..of course compared to the trans slamming into the frame with the broken mount, the poly was a world of difference.
Old May 19, 2004 | 02:34 AM
  #23
StoneRhino's Avatar
I installed an energy supsention poly mount on my 86 IROC after I broke the trany mount on that, and I never got rid of the vibration after that.
I just installed one on my 94 a few weeks ago, and only have the vibrations at 80+ and at different throttle posistions, which I'm hoping is the torque arm bushing.
IMO it's 100 times better then having the stock mount break at the track.
Old May 19, 2004 | 02:48 AM
  #24
dhirocz's Avatar
My experience is that some cars vibrate with them, some dont. Why? because rubber insolates vibration better than polyurethane which is better than solid. In other words, if you have a slight driveshaft vibration, it might not become apparent until you stiffen up the closest rubber mount at the trans. If some of you guys have cars rattling your brains out, it may be a driveshaft out of whack. Also some guys run adjustable torque arms; it might be telling you that your pinion angle is incorrect.
I run a poly torque arm mount and trans mount and noticed no more vibrations than the stocker.
Old May 19, 2004 | 03:04 AM
  #25
Aeromaks's Avatar
After i installed mine, yes after 80mph i had a hard vibration, but after some miles, it is actually good and very little additional vibration, best bang.
Old May 19, 2004 | 03:05 AM
  #26
Aeromaks's Avatar
Old May 19, 2004 | 08:54 AM
  #27
ping0317's Avatar
I went autozone and purchase a cheap *** trans mount only for $17.99 that comes with life time warrenty. I just bought because this is my 3 mount installed. 1 stock mount from Gm and 1 from Energy Suspension mount both broke on me! I am tired of paying $45+ for a trans mount. Do you thing this cheap *** one will work? If it breaks at least it is under warrenty... But I am thinking of ordering the LS1 mount today too....
Old May 20, 2004 | 12:48 PM
  #28
CamaroGuy22's Avatar
Well my thread has been resurected, my trans mount broke on me last wednesday night...i am going to autozone tonight to get the energy suspension one. I will let you know how it goes.
Old May 20, 2004 | 02:05 PM
  #29
ping0317's Avatar
question, how/why does the trans mount break?
Old May 24, 2004 | 12:04 AM
  #30
apick42's Avatar
Question
ok well someone said that the poly mounts will not allow the correct angle of the ds. my question would be, is the trans too
high or too low. i installed one of these mounts and my car
vibrated like hell , i removed the top metal bracket and that helped a lot but did not solve all the vibration problem so i
bought another ds had it balanced and new joints installed
but above 80 it still vibrates but not as harsh. i really do not want
to go back to a stock mount.
PublicEnemy1
Apr 7, 2015 12:21 PM
Jason Short
Jan 19, 2015 06:34 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
rpm4lalo
Aug 3, 2002 02:35 PM
