Poly Trans Mount
www.thunderracing.com
Here's the one for LT1 cars: http://www.thunderracing.com/index.c...yid=1069#P1249
Originally posted by OneFlyn95z28
BTW it is going to sound like you broke some thing after you put it it. Just make sure you bolted every thing up and ignore it.
M6/ poly mount owner here........... No problems or noises what so ever out of my car with the poly mount!! Make sure your shifter is not hitting the center console after the install since it will be sitting higher, if it is lose the backing/ preload brace on the poly mount. It wont hurt anything as mine is not installed with the plate and it has never failed in any way!!
