Part name
Part name
A.m everyone. I need to know the name of the part that's inside the housing after you take off the the slave cylinder. It has a rubber boot and a metal rod in it that pushes on the clutch fork. Just found mine was bent and has cracks in it.
Re: Part name
Assuming from your screen name that this is with regard to the slave cylinder on an LT1/T56, the "clutch actuator pushrod" is an integral part of the slave cylinder, aka the clutch actuator cylinder. You would have to replace the entire slave.
Re: Part name
Thanks injuneer. It's in stock gonna get it with dot 3 fluid.and go thru the bleeding process.hope I get it running today. And it is a t56 lt1 my friend used my name while I took it out. Thanks again
oldschool
Feb 9, 2016 09:21 PM
