park doesnt "click" in
Old Jan 29, 2006 | 01:10 AM
Daniel6718's Avatar
learned a new problem today...i ALWAYs use my parking brake..and good thing i do...parked real quick the other day and got out for split second and as i did i realised my car is slowly starting to move still...park wont "click" in unless you put the gear selector in park and juggle side to side front and back...every other gear works perfect! hold it in first it stays nuetral is nuetral and have no problems with reverse, im hoping its a problem in the console somewhere can anyone direct me?
i know its not the bracket on the side of the pan...and its barely off...
thanks
daniel
Old Jan 29, 2006 | 08:16 AM
12SCNDZ's Avatar
Re: park doesnt "click" in
Your shifter cable needs to be adjusted. Put the car on jackstands and disconnect the shift cable on the transmission lever. Push the lever all the way into park. Double check this by making sure the driveshaft doesn't turn. Put the shifter in park, and then see how much distance you need to adjust the cable until the cable eye is even with the lever ball.
Frank
CPT
Old Jan 29, 2006 | 12:16 PM
Daniel6718's Avatar
ok thanks alot frank...this would cause me to still have all my other gears except park?
thanks
daniel
Old Jan 29, 2006 | 12:17 PM
12SCNDZ's Avatar
Yes it can prevent only park.
Frank
Old Jan 31, 2006 | 06:48 PM
Daniel6718's Avatar
thanks frank for the help...it took an adjustment or 2 on the cable, but it works perfectly now!
btw love the transmission and the support after i bought it and have it back...frank has worked with me throught a few bugs since i have gotten my car back and none of them had to do with anyhting he has done!
thanks
daniel
kandied91z
Sep 30, 2015 11:43 PM
autoxr166
Sep 25, 2015 04:21 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
meissen
Aug 11, 2015 06:05 AM
