Options to Replace the 2.73 on 1997 Z28
Old Mar 23, 2006 | 05:36 PM
  #16
1SlowFormula's Avatar
Re: Options to Replace the 2.73 on 1997 Z28
Originally Posted by crb806
how do i know if i have a series 3 or 2 carrier, and would the 373s be rougher ont he rear end and tranny?
Well youneed to provide more info about your vehicle to know anything... And 3.73's are not harder on the rear or tranny unless not set up right...
Old Mar 23, 2006 | 10:13 PM
  #17
crb806's Avatar
1995 with 323s i believe it is a series 3 carrier am i correct
Old Mar 24, 2006 | 12:30 AM
  #18
mike 96 ws6's Avatar
Yes, as far as factory GM RPO production components. Only aftermarket gear suppliers provide a gear set that will provide a ring and pinion gear that will allow mounting a 3.23 ratio on a series 2 carrier.
And no, GM never used spacers to adapt 2 series carrier - 3 series R&P components.
Old Mar 24, 2006 | 09:40 AM
  #19
Demon's Camaro's Avatar
Easiest way to determine if you have a 2 series or 3 series is; can you select the 1 on your shift console? If not then you have 2.73s and a 2 series carrier.
ScottZ
Mar 3, 2004 01:34 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
30thZ286speed
Aug 3, 2002 04:54 AM
