It ONLY shifts DOWN!!!!
here are my test results:
With the engine off:
From Park I can move the shifter all the way to 1st and the gear selector lever on the tranny actually goes to 1st.
If the gear selector on the tranny is in 1st (and so is my shifter) I try to move it to park, the tranny will stay in 1st.
Is the shifter pushrod bent or something???
In a nutshell: It will only shift from Park -> Neutral -> OD -> 3 -> 2 -> 1st
but it wont do the opposite!
Re: It ONLY shifts DOWN!!!!
simple question!
The reason this happened is from removing the engine and pulling on the tranny
I guess I could always just leave the gear selector on the tranny in OD
Originally Posted by shoebox
Have you checked the shift cable on the transmission?
.Happened to my buddy's '96 TA ..... the 2 bolts holding the shift cable bracket on the driver's side of the tranny pan came out, and he couldn't get the car to shift all the way back to park (think he could get as far as neutral maybe?
). Get under the car and check that out first, then get back to us Thread
WobblySausage
Oct 7, 2015 10:09 AM
