OE Pilot bushing ( with grooves). Where to find
Old Mar 12, 2006 | 08:41 PM
cdb95z28's Avatar
I`m replacing the OE pilot bushing on my 29K mile `95 T56. The OE bushing has the small grooves on the I.D.. I believe this probably better than no grooves, as the grooves can retain some lube. GM dealership says there is no # for a bushing only the bearing is available. Anyone got any ideas?
Old Mar 12, 2006 | 08:50 PM
hotrod18_69's Avatar
Re: OE Pilot bushing ( with grooves). Where to find
Roller bearing. Got my from car-quest. $20 Any smallblock chevy will work..
Old Mar 12, 2006 | 09:36 PM
cdb95z28's Avatar
I don`t want to use a roller bearing. If it comes apart, it could be big trouble and waste a flywheel/clutch.
Old Mar 12, 2006 | 09:38 PM
cehan's Avatar
The part no. for the bushing I used is PB656, which I got from a local bearing supplier. It goes in dry, do not lubricate it or the pilot shaft on the trans.
Old Mar 13, 2006 | 09:35 AM
Bud M's Avatar
Ordering the OEM part should get you the stock bushing, regardless of whether they call it a bushing or a bearing.
Old Mar 13, 2006 | 12:29 PM
wrd1972's Avatar
I ordered the bushing being described and got the roller bearing.
The bearing works well, just ensure it is packed with grease.
96SilverRam
May 5, 2015 09:56 PM
BigWil
Mar 29, 2015 12:24 PM
dbrockma
Feb 16, 2015 02:56 PM
Jason Short
Jan 19, 2015 06:34 PM
bossco
Nov 29, 2014 10:18 AM
