OBD conversion tranny fix?
Old Jun 10, 2004 | 09:42 AM
WS Sick's Avatar
I have a 97 with an OBD 1 conversion done to it. I thought before my rev limiter was set wrong, but when I looked the program over through tuner cat the rev limiter is set way higher than my problem occurs.
I have been fighting this for a while and have done everything from having the tranny looked over to replacing the secondary ign (and opti cleaning). I finally just gave up and started shifting sooner.
Anyway a guy thats into LT1s like myself said it may be because I have an OBD 1 computer and a 3000 stall, he said he heard here that that can cause problems.
My problem is a late shift, acts like it hits the rev limiter right before it shifts (6300 rpm). I cannot manually hold the gear past this either, but sometimes if I let it shift itself it revs past this a little and shifts fine (with a slight hesitation). Its kinda frustrating because I know I have a tenth or two of time if I get this fixed.
Any Ideas?
Old Jun 10, 2004 | 10:11 AM
Koby's Avatar
That sounds like a typical problem with OBD I and a higher stall convertor. You should be able to get it fixed with a computer tune though.
Old Jun 10, 2004 | 10:12 AM
WS Sick's Avatar
I have PCM for less tuning now, should I tell Brian what its doing and he'd know what youre talking about?
Old Jun 10, 2004 | 10:46 AM
Brent94Z's Avatar
Super Moderator
I'll move this to the Drivetrain forum because I think more guys there can help you. But, you might also want to post this in the programming/diagnostic forum as well.
BigWil
Mar 29, 2015 12:24 PM
siguy
Nov 27, 2014 10:07 AM
MislMan
Jul 19, 2002 11:41 AM
